318/360 flywheel 130 tooth
looks like a 318 neutral balance, NOT a 360 external balance flywheel, not bad for $50
still available , google : mopar flywheel identification # 2264598 for application & interchange guide
the rare 360 flywheel is part # 3410916 easy to identify by the three 1" holes drilled on the back for balance
yours is a part# 2264598 which is a neutral balance, the good news is a neutral balance flywheel can be balanced to work on any LA 360 or a cast crank 340,
