booker t jones
1968 block less than a thousand miles since rebuild steel crank windage tray summit raceing cam&lifters it has closed chamber shaved heads .40&ported eldebrock intake2 inch 4 hole spacer holly 600 with trick kit choke horn shaved mopar electric dist msd box solid state voltage regulator&alternator 904 transmission rebuilt at the same time with b&m shift kit boss hawg 2600 stall converter this info is what I was told by the guy who sold me the car I don't have any documentation&he did the rebuild I drove the car about 500 miles and it ran great will not sell seperatly engine is in car you can start it check compression whatever then
we can yank it car is in Radford va no shipping 1500.00
