M Mopar Tech Well-Known Member Joined Aug 8, 2016 Messages 54 Reaction score 12 Location Memphis,TN Sep 30, 2020 #1 I am swapping a 360 into a 1974 dart 318. Is there a good link to the modification to the driver side mount spacing for this swap?
plymouth4onthefloor FABO Gold Member FABO Gold Member Joined Dec 1, 2017 Messages 315 Reaction score 318 Location Switzerland Sep 30, 2020 #2 DIY is pretty easy and simple. You have to cut one of the ears, attach it to the block. You need a L shape steel ( from a U bar or so) and weld it to the bracket. Mark the hole and drill it.
RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member Joined Jun 7, 2010 Messages 104,837 Reaction score 102,430 Location Georgia Sep 30, 2020 #3 Or you could just use a spacer.
Mtrhead Ace of Spades ♠️ Joined Sep 19, 2018 Messages 4,602 Reaction score 3,250 Location S.C. Sep 30, 2020 #4 73 and up K members changed to spool mounts....trick only works on 67-72
Mtrhead Ace of Spades ♠️ Joined Sep 19, 2018 Messages 4,602 Reaction score 3,250 Location S.C. Sep 30, 2020 #5 Ok..I see it also works on spool mounts....Niceee!!
M Mopar Tech Well-Known Member Joined Aug 8, 2016 Messages 54 Reaction score 12 Location Memphis,TN Sep 30, 2020 #6 Thanks guys.
