prorac1
i have a couple other threads going leading up to this.
Here's the quick and dirty.
We're "cleaning up" a dirty old abused 1983 318 out of a ram charger.
Were installing:
Main bearings
Rod bearings
Oil pump and pickup
Timing chain
214/224, .444/.466 112 LSA cam
Lifters
And valve springs.
The last edition is what's causing us issues. Valve springs.
Being a 1983 318, it had rotator style exhaust retainers. That part has already been tackled, and we got some used intake retainers to replace the rotators with.
Problem is, the 2 groove rotator exhaust valves have the lock grooves further down on the stem than the 4 groove non rotator older style.
This causes the spring height to be lower than optimal. It also causes us to run into coil bind, or close to it.
So we need to buy new exhaust valves for use without rotators and the lock grooves higher up.
Here's the new issue.
The valve I currently have is listed as a 45 degree seat on rock auto.
The valve I need is listed as a 43 degree seat.
2 degrees could cause an issue.
Our plan was to buy new springs and hand lap them in. Now I'm not sure that's a possibility. A valve job is out for now as the budget is tight.
Thoughts.
Were installing:
Main bearings
Rod bearings
Oil pump and pickup
Timing chain
Lifters
And valve springs.
Thoughts.
