[WANTED] 318 forged crankshaft
440BelII
Darien Center, New York
Rating - 84.6%
11   2   0
Searching for a good forged crankshaft for a 318 motor that I'm putting together. It can be from a 273, 318, or 340. I will take a crank or buy a whole motor if need be as long as it's reasonable because I only need the crank. I'm located in Western New York, between Buffalo and Rochester and need it to be within a reasonable driving distance. Let me know what you have if you can help. Thanks in advance.
Remember the 340 crank is different and balanced differently. So that could lead to a vibration if used with 318 internals, even though the balancers are both neutral.
I have both a 273 and a 318 crank, but I fear that shipping would kill the bargain.
I was told only thing difference between the 340 crank is that hole drilled for balance and purposes and then they were shot peened
