[SOLD] 318 good running engine
HotRod20
Plymouth, MI
Mid 70's 318 complete long block. Cast date is 7-5-? hard to read, could be a 3 or a 5 not sure.
From Air Cleaner to Oil Pan, and Fan to Flex plate. Engine has mopar performance valve covers, electronic distributor,
new ignition wires, 600cfm 1850 Holley, Street Dominator intake,msd coil, includes complete exhaust for A body Dart or Scamp.
Has very,very slight lifter tick when cold, but goes away when warmed up. Just pulled from my 72 Scamp. $1,200.00 you pick up in Plymouth Michigan.
I can load it with a engine hoist.
HotRod20
Any more info is the 318 std bore? Camshaft specs? Approximate miles on engine? Also is the crank drilled for a pilot bearing.
