podunkracing
318 fresh built motor with around 150 miles.block is a 85' model.motor has factory steel crank,std on brg.stock rod's,sealpower .30 over hypo piston's,10.0 on compression.block has been decked,windage tray,car oil pan,new roller timing chain,h/v oil pump,comp 273 cam,comp matched springs and retainers,j head's,that have been fully ported,1.88 and 1.6 stainless valves,steel adjustable rockers,comp pushrod's,weiand 7510 single plane intake.head's have been decked,msd pro billet distributor and wires,stock water pump assembly,fluiddyne balancer,chrome vale covers,arp rod bolt's,and im sure there is some stuff i have left out.
Motor run's good and strong,holds good oil pressure 65psi warm and 40 ideling.motor in full body duster with 4 speed run's with my buddies 7.90 camaro.all motor.
Feel free to ask any question's,located in paducah,ky 42003
it is in car and can send vid's and pictures.will also be posting some up soon.
Asking $2200 o.b.o
Asking $2200 o.b.o
