318 LA Block Hydraulic Roller
Moparturbo
Ohio
Hello All,
I am pretty sure you can do this but I wanted to ask to make sure. I have a 318 non magnum hydraulic roller block. Can I install a regular hydraulic cam and lifters? I have everything for the flat tappet. Cam, lifters, timing chain and
pushrods to match. Using an electric fuel pump also so will not be using the fuel pump eccentric.
Thanks
