Professor Fate
Push the button, Max...
Not my work!!Nice ^^^ Frost Plugs . . .
Just a nicely captioned pic I stole...
BE CAREFUL HERE. That is sloppy "recent" paint. Do you KNOW that the engine ran and oiled OK? ----Possibilities---
1..LA block, LA heads
2..LA block converted to use Mag heads WE KNOW NOT because you have shaft rockers
3..Mag block with LA heads---WILL NOT OIL the shaft rockers because mag blocks don't have the block oil passage
4..Very late "roller block" LA block with some sort of LA or original heads. these were built a few years, used factory TBI injection, used factory roller cams just like magnum, but had the block oil hole and used LA style shaft rockers. Look for the roller lifter "spider" retainers and block bolt holes down in the valley. That might explain the "both" motor mounts
That’s what I thought .That block has both styles of engine mounts.
If I'm not mistaken, headers don't completely cover them, hence...the silicone.What was in those holes from factory ? The manifold covers them
Roller lifters are held straight by a set of parts commonly referred to as "dog bones" and a "spider" retainer. The lifters are machined taller and have flat surfaces opposite one another for the dog bones. These hold the lifters so the rollers stay 90°to the cam. The spider has "legs" that sit on top of the dog bones to hold them down and is bolted down with short bolts in the valley over the cam. Once the heads are removed all this is readily visible. LA engines have the usual flat tapper round lifters. A retro fit system is available with link bar hyd roller lifters and a reduced base circle cam for older small blocks. The link bars are easily visible with the heads off.Yeah I don’t know what that is or how to tell unless removing it from the car . How to tell if my heads are magnum ? Cause I wanted to use them on another LA motor . This was spare motor I got . I don’t want to pull entire motor out of my car . I wanted to put hood heads from this motor as I k ow it ran and seemed to run pretty well last year
Was set up with la fuel pump amd timing cover and water pump .Is it set up with a manual fuel pump on the timing chain cover?
Lets see some pictures of the cylinder head chambers from the heads that you pulled off.
Cylinder head numbers in the rocker shaft area too please.
Thanks
Considering your pictures, shaft rockers, and the presence of the smog holes, these are likely desirable LA heads. You likely have the closed chamber vs. the open chamber.
In the early 90's, just before Dodge went to Magnum, you had crossover years. 91, 92, some 93 360 were cast with the longer lifter bores and yet fitted with flat tappet cams. Also in the casting, there was provision for shaft rocker oiling required for the flat tappet. These will have an oiling hole through the deck. You have not removed the heads yet, I assume.
The bosses in the valley may or may not be drilled. You may or not have roller lifters. Magnum blocks will also have engine mounts in the center of the block with jacket drain at the driver rear of the block. LA blocks will have the water jacket drain just behind the motor mount on both sides. (Pain in the *** to drain with headers.)
block cast says it’s 91 318 motor . Which is first year for magnum . But yeah someone put this motor together as block was zero . But all guts of block are magnum - roller cam and lifter , the spider thing
Confusing - cause everyone says la has no roller cam , also not 302 heads on it for sure .Well that is interesting Because everything is pointing to it being a '91 318 TBI roller cam engine with the factory 302 closed chambered heads and factory mopar rocker rails.
If this is true, then it is a flat topped piston with factory 9.2:1 cr and full floating connecting rods.
Just like this '91 318 TBI roller engine that I converted to Edelbrock 4bbl carb.
Factory pistons .040 ths in the hole, no valve reliefs.
Let's have a look at your Closed Chamber heads.
'91 318, ^^^ roller engine, factory 302 heads.
Engine came out of a '91 W150 Dodge Pickup.
Worth hanging onto.
I had a 86' 5th ave (318 LA) that had the roller cam. Good running motor. My understanding was it was the 1st or 2nd year of the roller cam, if my memory is correct. Yes, I'm getting old as the rest of us.The TBI 318s are the roller engines before they came out with the magnums.
