[318 LA] main bearing info needed
If the crank has a tapered radius choose a bearing with the right chamfer. Stock cranks did not have a chamfered bearing.
you may also want to use a later #3 thrust bearing if it can fit. I believe they have a wider thrust area to take more loading.
Thanks for info u are correct on wider thrust after 1974 .
I went back and looked at the pictures of the Chrome-A-Shaft crank box. It does show radiused 2 inch rod journals but doesn’t mention anything about the mains. That’s going to have to be looked into a little closer. You have a picture of a main journal and a dial caliper measurement? Being such a custom piece made for Bob Glidden, it’s possible it may have some odd main bearing journal measurements like small block Ford.
let me check !
let me check !
Those look like rolled radius fillets to me. That’s going to take some checking around. Do you have a main journal diameter?
