318 Megasquirt base map
vgv8
Member
Hey all, just wondering if anyone had a base map for a megasquirt setup on a 318, looking to just get it started and tuned from there. I am using 318 heads, small port holley street dominator intake with two 65mm throttle bodies and injectors from a 297kw LS1 and Innovate LC1 wideband. I have been playing round using the stim and different sensors hooked up on my bench, i.e. calibrated TPS, Coolant Temp Sensor, Intake temp sensor etc... on the bench. I dont want to wipe a lobe of my new cam so I can either use a known good carb for and points dissy running in or maybe someone is willing to share a base map. Thanks
