[WANTED] 318 Motor Mounts for 66' Cuda
Then keep your eyes peeled for a V8 centerlink, too- if you don't already have one.
And the V8 throttle pedal/cable assembly.
Yes, definitely need both of those. Had a center link sourced but it ended up being damaged.
An early A has the same K frame for slant or SB.
All you need is a set of factory 273 mounts, and maybe the dropped center link.( I have seen 2 that worked without it).
The pass mount needs a tab added for a Magnum engine, but I dont think its needed for an LA motor.
Sounds right.
I will definitely need the V8 link that has the drop down in it.
