318 rebuild noise
JOHNNY MOPAR
LAUNCESTON TASMANIA
hi everyone have a slight problem with my 318 - fitted timing cover , balancer and water pump today and when i turn the engine over by hand it makes a clunking noise up the front it seems to be coming from timing chain area , so i pulled everything back off and turned over again without the balancer on , it had disappeared thought maybe a timing cover bolt was touching somewhere put everything back and it did the same thing but if i back all the bolts off and loosen the timing cover you can just hear the noise .
the timing cover was a bit warped so i evened it all up with a large file and a flat rule could this have caused a problem somewhere ? cheers
I have seen and heard this from many who ruined their motors installing the timing cover. The two lower bolts on the drivers side of the cover I believe could be your problem. If you put to long of a bolt in one of these holes it pushes through the cylinder wall, and the skirt of the piston comes down and hits it. When you loosen it up the noise will seeam to get less but it will still be hitting the cylinder wall which is now shot. If you would go to put water in this motor and this is what happed you will fill the oil pan with water. This is a common mistake on alot of do ot your self guys that either never had the right bolts or just through everything in a bolt bucket to sort later. The bolts are specific to their holes , I have seen guys take the power steering brackets off and use the same bolts they took out without the use off the bracket or washers, the bolts were to long and they ruined their engine. Good luck I hope this isn' the case. Drop the oil leave the plug out and fill the block with water. Wait alittle while and see if the water starts seaping out the pan. If so , this cannot be repaired with out sleaving the block .Sealers will no work hear because you have alread egg shaped the cylinder
