TurboGrimace
Member
my 318 was built by the previous owner. IIRC from nearly a decade ago, it has a mopar purple shaft cam in it (the biggest he could get of course), 340 heads (doubtful probably stock), rpm performer dual plane manifold, avs 650 carb, and an electronic ignition box.
back in the day it ran strong. the cam is incredibly lopey and idle is rough. I just got it running after sitting for two years, which only took some cleaning and some fresh gas. before i packed it away two years ago, it was starting to become a dog, so I checked the timing and set it to 12 BTDC and it ran even worse. I continued to advance the timing until it ran a little better, but it required a significant amount of advance to get a little power. Still really weak though. The timing advances with increased RPM, but there is no difference in timing with the vacuum line hooked up or taken off.
Clearly (for me) part of my problem is an untuned carb, but I wanted to get the timing set correctly first before i started screwing with the carb. It originally had a 750 cfm eddie with weighted secondaries. I'm tempted to put that back on and use that because I liked the way it ran with that.
I know this is a lot of information and there are a lot of potential issues, but I was hoping that I could get some guidance on where to start, what to do, what to change. Even some info on what may work better with my mysterious combination.
Thanks a lo guys!
Thanks a lo guys!
