318 to 440 wiring harness changes
Big Block A body Tech
  1. Logan Woloszak
    Logan Woloszak Member
    20
    2
    Mar 8, 2019
    Merritt Island Florida
    Local Time:
    5:11 AM
    I put a 440 in an originally 318 68 barracuda. The 440 has an electronic distributor meaning I had to get a Mopar orange box ecu. I've followed the wiring diagram for the ecu but I'm still not getting spark. The ballast resistor and coil are getting power.
  2. george joseph reid
    george joseph reid Well-Known Member
    101
    39
    Aug 22, 2018
    Elmira Oregon
    Local Time:
    2:11 AM
    Allpar has some good info on this conversion.
  3. dragfish
    dragfish Well-Known Member
    79
    19
    Dec 13, 2006
    Local Time:
    4:11 AM
    Did you switch voltage regulator to electronic one points are different
  4. Logan Woloszak
    20
    2
    Mar 8, 2019
    Local Time:
    5:11 AM
    I was able to get the car running with the mechanical voltage regulator. As long as I hook one side to the alternator and the other to the ballest resistor it should charge right?
  5. TheGrateRonzini
    TheGrateRonzini FABO Gold Member FABO Gold Member
    707
    574
    Oct 25, 2017
    Western New York
    Local Time:
    5:11 AM
    I could be wrong, but do you need a different alternator? Just saying, cause I brought a one wire to use to break in a motor with an electronic dizzy and orange box and was told it wouldn’t work and I needed a later square back
  6. dragfish
    79
    19
    Dec 13, 2006
    Local Time:
    4:11 AM
    Never tried that when ever I switched ignitions I changed voltage regulator, electronic VR's are reasonably priced and look stock
  7. dragfish
    79
    19
    Dec 13, 2006
    Local Time:
    4:11 AM
    no as long as your using stock wiring If your using something like an Evans wiring harness I think they update to 2 wire don't quote me on that though I have a 67 belvedere and is 1 wire alternator with an electronic voltage regulator I run the chrome box
    • Like Like x 1
