Agent_Orange
Hey everyone, thanks in advance for your help.
First off lets get the basics out of the way. I have a 1974 318, basically stock as far as I know. It does have a very mild cam, but I have NO other information on duration or lift. heck i don't even know the brand. :banghead: Behind the 318 is a TCI streetfighter 727 and I don't know the TQ size or brand. The engine has a Edelbrock Preformer 4 barrel carb with electric choke, I believe it has electronic ignition and it does have a vacuum advance on the carb. Currently the vaccum advance is plumbed into the manifold and not the carb. With a vacuum gauge also on manifold vac, i'm pulling 14-15 lbs at idle in park. It does have a steady, fast flutter of around 1-2 lbs. Also, I running full tubed headers into 2 1/2 exhaust out the back
When it comes to engines, i probably know just about enough to get myself into trouble. SO, hopefully you guys will allow me to lean on ya here to help me troubleshoot issues.
With no further to do: The first issue I have is with the idle of my car. I don't have a tach so i cant give exact numbers, but in order to keep the car from dying when put in gear, the idle at park/neutral is easily 500 to 1000 rpm higher than it is in gear. So as you can imagine, when i put my car in gear you can definitly feel and see it.
Another issue, or maybe another symptom of the first O
Third Issue. I know my car is a v8 without overdrive, but i'm pretty sure my engine is running really rich. The car has a very strong smell of unburnt gas out the tailpipe. That, and from what i've read, a 318 should be putting down somewhere around 20 mpg. Not the 12-14 mpg that i'm currently reading. It should also be noted that i have .223 gears and 245/60/r15 tires.
:cheers:Thanks agian everyone. ANY advice to help point me in the right direction would be greatly appriciated. :cheers:
