[FOR SALE] 340 1975 Dodge Dart sport $6500 OBO (California)
UGROGUE
New Member
California
Rating - 0%
0   0   0
I have a Dodge Dart Sport with a fully built 340, an original 360 4 speed car(dont have the original setup).Non-Oped no back fees The motor has been built for racing but light road use is ok, its very loud and sounds mean as hell. I started doing the body but didn't finish so its in primer. It just needs the body finished and itll be an amazing toy/hotrod. The hood had a dent in the middle but I have a spare hood thats clean. The car has a slight rust rot spot in the lower corner about 2in wide, but its workable. Best offer accepted but I have a serious limit based on the motor work. the names Art asking $6500 OBO, location is California
-Aluminum Edlebrock Heads
-14.1 Compression
-Holly strip dominator intake
-TTI Stepped Race headers to a 3in collector
-3in exhaust turned down at the rear end
-Dyno Max Race bullet mufflers (3in)
-603 lift comp cam
-Holly double pumper with a Pro-form 850 CFM body
-Stainless roller rocker
-Brand new cam bearings, main bearing and rod bearings
-CenterLine wheels all the way around
-Mickey Street Radials on the rear about 50%left
-good shocks front and rear
-8 3/4 rear with 456 gears and a spool, aftermarket axels.
-Torque Flight 727 with a B&M pro stick shifter and high stall converter.
-Frame connectors
-fuel cell
-good interior needs a carpet kit.
-gear drive and electric water-pump
-Front disc brakes
-etc
Neat car. Per forum rules you have to put a price or ad will be deleted.
