[FOR SALE] 340 .30 over pistons and rings
JKrebs
68 GTS
Greensboro MD
Rating - 0%
0   0   0
I have 8 340 .30 over piston with rings. The pistons are nearly new and the rings are unused. I wanted to use my X heads and wanted more compression so I'm going with an above deck set of pistons. $150 plus shipping. Pins and clips included.
Got a part# ?
Thanks
They are silv-o-lite 1267 .030 over.
I purchased a 68 gts motor to build up for my 68. The person I bought the motor from had had it rebuilt but complained that the motor had excessive blow by. I checked things out and found that the builder put standard rings on the .030 over pistons. I bought new rings and was going to use aluminum heads to get my CR round 10:1. I decided to use a set of x heads instead and I did not want to cut the heads down so I went with a different set of pistons to get my CR up. This is why the pistons are basically new and the rings are new.
