340 360 swap
dazedduster
Fort Bragg, Ca
Can Anyone Tell Me If My Intake Manifold, Oil Pan, And Pickup Tube
Of My 73 340 Out Uf A Duster Will Bolt On To My 73 360 Out Of My 73 Power Wagon. I Thought The Parts Were Interchangeable Put The Local Parts Store Has Diffrent Part Numbers For The Oil Pan
And Intake Gasket. Any One Done This Swap.
Well there corrct. The oil pan is different for the 360. The intake gasket will not matter.
Your intake will bolt on,the oil pan is different and the pick up tube would be differnt too ,because the pan is different.The 360 has a larger rear main cap and seal.Mrmopartech
When you try to put a 318/340 oil pan onto a 360 their will be a large gap between the pan and the seal/main cap, which makes them incompatible with each other, this is from recent expierence (this last spring when I put my 360 into my dart).
