[SOLD] 340 and 360 4 Bolt Ductile Iron Main Caps - New
Rocket
U.S.A.
I have a few sets of new ductile iron main caps available. These are Mopar Performance caps. I have sets for both 360 main and 340 main blocks. The sets include all 5 main caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on a 340 before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build . A line bore will be needed when installing new caps as well as some machining for the thrust bearing and #5 cap for the oil seal.
Price is $220 shipped per set in the lower 48 states.
PM me with any questions
Yes you would still be fine. The rear cap needs machining for the seal so most persons using them on a block I know use the stock rear cap. In the picture of the 340 I build in the add I only used the 3 center caps and it was fine (I did not have the front caps at the time I built that engine).
