CudaDemonSRT10
New Member
Located in Alberta Canada. Professionally built with all the best NEW parts. H beam rods, KB pistons (9.3 to 1 comp), Scat 4" stroke FORGED crank, Lunati hyd roller, 270/278,515/530,roller rockers,ported and polished W2 heads,Moroso 8 qt pan,Holley 750 vac sec carb, headers,billet dist,ARP bolts,high volume water pump, high volume Carter mech fuel pump.complete carb to pan. dyno`d at 465hp/505 ftlb @ under 5200rpm. (see dyno report)1972 dated block. Idles like a stock 318, and makes more power than a 392 crate engine! But bolts right in place of your LA engine. Video of dyno run available.Too many projects on the go already (68 Fury conv, 73 Dart 440,). I have $13,000 cdn into it,over 7 years of gathering parts. No trades please. Price is $10,000 USD, $13,500 cdn.
