74dusterman
74dusterman
I am starting to gather parts to build my 340. The block is a 69 bored .030. I have my eye on some TRW 2316 pistons from another member here. I will either be using a set of X heads or some worked over J heads with 2.02/1.60 valves. I have an Edelbrock RPM Airgap intake and Holley 750 carb. I am not sure what cam to go with. I was thinking about going with a solid cam and lifter setup otherwise Comp Cams XE268H. One question I have is will the adjustable rockers from a 273 work with the solid setup or will I have to get different rockers? I have the 273 rockers and new pushrods from a previous build so it would be nice if they would work. The car is a 73 Duster with a 4 speed 3.23 sure grip. I don't plan on seeing any track time, just street use and serious tire shredding. Any suggestions are appreciated. Thanks in advance.
