joshua dewitt
hey guys, any one ran the old mopar performance p4452782 factory muscle car reporduction camshaft and lifter pkg. 268-276-44degrees. vavle lift .429"/.444" on a center line of 114degrees. says idle to 5000rpm... it's new in the box....
i have a 318 going to run a .30 over with zero deck pistions. run the factory 318 head until i get better one.. possible 302's? have headers and a offy 360 dual plane, and a904 lock up off a toggle forr hwy only. and plan to eventually run 3.23-3.55 gears... is can going to run good for the street? with p/s , p/b and a/c... and will it have a nice lumpy idle or should i off set the cam by 2 degrees for more idle lope? any thoughts.... never delt with the factory purple 340 cam before.... any links to a sound bit on the idle quallity?
