eduardostewart
Hi guys,
newb here. before diving in i thought i would read the fsm for the "proper" steps. it seems that i just need to unbolt those 6 bolts and the crank pulley should come off? it's not pressed on or anything right?
as for the balancer, will this tool do the job for removal?
http://www.harborfreight.com/bolt-type-wheel-puller-set-69889.html
and this to install?
http://www.harborfreight.com/pulley-remover-and-installer-set-40749.html
