IndianaDodge
$1500 1973 340 std bore block & crank cleaned and ready for machine work. Block will need a .030 bore and crank will need .010 on the mains and rods. It comes with orig rod & main caps w/bolts, orig stock pistons & pins (Two have rings stuck), and orig rods. Also included but not cleaned are the orig J-heads (Minus the rocker arms & shafts) and orig 340 intake. No timing chain cover or oil pan. This was originally from a 73 Challenger if anyone is looking for a period correct 340.
