RPAGAN
Ended up with a bad block. I have a complete top end assembly consisting of:
Edelbrock 6077 Heads Cleaned, springs and valves checked
Crane Roller Rockers
Mopar Intake
Mopar polished cast valve covers
Custom Comp Cam Hyd Roller Cam and Lifters
Pushrods
Milodon Gear Drive
Oil Pump Drive W/Bronze Gear
ARP head bolts
Felpro 1008 Head Gaskets
Mr. Gasket Cam install gasket set
Asking $2400.00 for everything. Also have a complete balanced rotating assembly with:
30 overForged SRP Pistons
Eagle H-beam Rods
Fresh ground Mopar steel crank
Total Seal File-fit Moly Rings
King Rod and main bearings
Asking $850.00. Willing to a make a deal on everything and will include Milodon 8qt. Pan,oil pump and pick-up,timing cover, Water pump and aluminum pulleys. All parts are located in Hudson, Florida 34667
Mopar Intake
Pushrods
Milodon Gear Drive
ARP head bolts
Eagle H-beam Rods
