[SOLD] 340 engine
kyjoe1969
b-burg ky
up for grabs is a built 340 engine, engine was from a cuda i sold as a roller.engine has less than 400 miles.it was roughly A $5500 build back in early 2010 . engine has eddy heads & rpm intake.276/284 comp cam. 10.5:1 comp.(runs well on pump gas with the heads)i beam rods on forged crank.arp bolts though out. all machine work and balancing done on cnc machine.headers are sanderson ceramic.carb is a worked 750 demon with matched power valves for this engine.
no short cuts or cheap parts went in to this engine.
engine is located in brandenburg ky 40108
$3500 cash or pay pal ,or may take equal value truck/jeep on trade
i will ship this engine at buyers expense if needed, i can drop it anywhere in louisville ky, buyer must arrange it.also may be able to deliver to with in 100 miles or so from louisville at no charge.
