67GTConvert
I have this flywheel of unknown origin that I'm trying to identify,the guy I got if from told me if was from a small block,most likely a 340 but did'nt know what year.
Anyways,it has 130 teeth and looks like it would take a 10.5" clutch so that's a good sign but after I saw this diagram in another thread here it looks like it might be for a 73 340 going by the drilled hole on it.Does anyone on here have one of those and does this one look the same?
I'd imagine it would have the same casting # as a neutral balanced wheel and the only difference is the drilled hole,is that correct?
