I'm thinking about switching to a RPM airgap intake manifold. My question is will it out perform
my stock 70 340 cast intake. 3462848 casting number. Any opinions?
OEM intake is not included, but here is an old test that may help in your choice. Pick the best numbers within YOUR usual rpm range. Probably the RPM Air Gap, or even the "regular" RPM that's not listed.
Yes, it will perform better than stock. I run an RPM air gap as well because I wanted a dual plane intake for street and strip. It's a fine intake and I have had zero issues. Get one.
