Pabuhr
I have a 1970 A body K-frame removed from a 340 Dart. Most of you know the difference between this one and a regular V-8 k-frame. Has the coin welded to it for identification. Has the washers welded to the lower control arm pivots for reinforcement.
I am including the following items: sway bar, sway bar brackets, lower control arms with sway bar tabs, strut rods, radiator support bracket, sway bar links, and steering box bolts.
Local pickup only.
Located in N.E. Iowa.
Asking $350.00 for everything.
Local pickup only.
