jack the car up, remove the right inner tie rod end and the left outer tie rod end, remove the idler arm bolt, and move the centerlink and linkage to the driver's side until its out of the way (may have to turn the steering wheel). Once that is removed, you may or may not have to raise the engine slightly and pull the transmission sheilds to get it off of there.
Its really not that hard.
