replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,082
- Reaction score
- 8,019
This is a 340, that was built to run in a stick shift class, but the project got stalled out, and I don't see me ever finishing the car. Anyway, the shortblock is .030 over, has BME pistons with a small dome, H beam rods, factory steel crank, rotating assy neutral ballanced, the top end is a set of early direct connection W2 race heads, they have ferrea 2:05/1:60 valves, unported, bronze guides, double springs, positive seals, Smith brothers 3/8 pushrods, ductile iron direct connection offset rockers and stands, comp 305 magnum solid cam, roll master timing set, unsorted Victor W2 intake. The engine has been ran a few times with a set of J heads, and then was redone with W2 top end, and only driven around the neighborhood a few times. Willing to drop off at fastenall for shipment, or local pickup is fine also. Located in Concord N.C. and asking 4800, thanks fabo
