[FOR SALE] 36-1 Crank Trigger Wheel
wish4hemi
Laser-cut 36-1 crank trigger wheel. 8-1/4" diameter, 1/8" thick steel with a 1/2" hole in the center. Eight slots for a variety of uses. Also has the Chrysler harmonic balancer bolt pattern drilled in it. This bolts on the front of your crankshaft pulley for quick and easy crank positioning that works well with aftermarket ignition or EFI systems.
$32 shipped USPS flat rate
