Swingn’71
360-j heads mp springs 188/160 250. 84 360 smoggers 50. 273-920 heads comp 901-16 springs 250. Offy low rise dual quad small block intake and 600 Eddy’s air cleaners and linkage 600. Worked with above 67 920 heads. Holley 1850-3 600 carb vac secondary 100. Comp 484 lift hyd cam small block used with lifters in box about a thousand street miles 100. 833-o.d. Trans recent bearing seal kit clean 450. 67 273 short block stuck 150. Stock 273- Valve covers 25. Not commando. Eddy air gap small block intake 250. Eddy 1405 parts carb 50. Rim blow wheel and center NEEDS RESTO 25. All parts are located in Mass 01473. I am not a shipper so pick up only. Thanks.
