[FOR SALE] 360/440 cast crank manual flywheel
Mrmopartech
St.Lazare Quebec Canada
Up for sale is a 360/440 cast crank that has been refaced and ready to install.If you are interested in the part give me a call or text,or email me .If you have race parts for a big block we could trade.Asking 225$canadian plus shipping. All the teeth are good and is only for cast crank engines.thanks,mrmopartech/scott
Go to my profile for info:
You need to edit the first line of your ad. It says you're selling a cast crank.
By The way the 360 flywheel is balanced different than the 440 flywheel. The 360 has three big holes drilled into the back of it.
I don't know the weight difference but here are the wheels. These are 143T truck wheels.
360 Top
440 bottom.
Never saw a 440 cast crank with a flywheel. All the ones I've seen had forged cranks if they were in a manual trans vehicle. All the cast cranks I had didn't even have a hole drilled for the pilot shaft or bushing. The photo above just looks like one for a forged crank. that little cut in the edge was just to neutral balance it. You'll see that in other applications too, along with small drill holes that do the same thing.
Correct Cudamark. I've had several 70's 440 4-spd trucks and they had forged cranks and the heavy 6 pack rods all the way through 1978. 400 4spds had forged cranks as well. Of course 72 was the last year for a 440 4-spd in a car but 400 4-spd cars with the 130T wheel had forged cranks too.
If you text me,I can send you pics.
All the pics of the flywheel are on my phone,mrmopartech
Go to my profile and text me and I can send you pictures.
Second ,I have the diagrams in front of me from larry shepard to re-drill any neutral balance flywheel.Now this type of flywheel can be used on a 360,383-400+440cast crank engine with minor mods,if any of you wish to talk about this,feel free to call me and I show you how wrong you are.As I am going to take larry shepards word before yours.So this is a 360 cast crank flywheel and can still be used on the other engines.So if you do call,I will mark your number down,and call you back on my dime,I can afford it.mrmopartech
How about you follow the rules and post pictures of the flywheels you're trying to sell.
FYI the Larry Shepherd you may have talked to recently is the son of the original Larry Shepard that wrote the book on Mopar. And the son doesn't know Doodles squat about small blocks I've talked to him.
I have a 1973 W200 360 4-spd that my dad bought brand new that has exact flywheel in it. Your welcome to come look at it. I don't need to talk to any one else. I've owned over 200 Mopars since the mid 70's and I know exactly what I'm talking about. To try and rebalance a 360 wheel for a 440 will require more Mallory than it would be worth.
Can't you post pictures from your phone? This 2020 by the way, not 1990.
OP never said if it was a car or truck flywheel.
All the 360 fw that I have seen have the 3 big holes like in the pick. I have seen about 20 or so. My own personal stuff has been a 74 Cuda 360, a 74 Duster 360, a 74 Dart Sport 360 and a few trucks. All had a 10 inch clutch. Even a 1 ton dually. Never had a cast crank bb with a manual trans. I have had a couple of the cast crank 340s as well. Kim
