Captain Chaos
Please read slowly before replying because I'm getting mixed info on this, thanks.
I have 1997 5.9. I will be using a carb so I don't need the pickup ring for the crank sensor, what flywheel, specifically do I need for this? I know the engine is externally balanced. I assume an early style flywheel would work, but which application? Thanks in advance.
