Lazares81
"Mopar: You're either with us, or behind us!"
So i was finally putting together the 360 for my swinger and was done with all xcept the harmonic balancer, started to put it on backyard style with some wood and a hammer and some patience
The problem is that it appears to me the pulley is approx 1/4" from touching the timing chain cover, at the section of the cover that has the timing marks, and the bolt i got from summit still doesnt catch any threads with the spacer on it, if i take the spacer off then i can catch 4 threads.
Is this normal with a brand new harmonic and an old crankshaft that has been rebalanced and honed? Is this normal for the harmonic to be so close to the timing chain cover? Can i get a longer bolt and just tighten it down till the balancer sits flush?
Any advice will be great help and much appreciated
