360 balance
camd64
Remember Landy
cedar park, tx
I am going to be pulling the 318 from my dart to put in a 360. my question is since i already have a good balancer and high stall conv., flexplate meant for the internal balance 318 will it work with the 360 if i put in one of the internal balance cranks from Eagle? they run about 300 and since i don't aleady have a 360 crank and if i got a stock one i would have to go buy those parts again im thinking i could save a little coin? anyone else gone this route? Johnny.
No. All you need is the B&M flexplate for the 360 non Magnum. You need the 360 harmonic dampner(balancer). The fact that a crank is designed for internal balance does not mean it's the right wieght to work with a stock assembly. It means the crank's counterweights are beefy so it can be internally balanced without needing Mallory metal. And sometimes even that isnt entirely the truth...lol. A 360 crank & bearings kit runs about $200 and will drop right in. But you'll need a 360 dampner ($100 new for non SFI or less for used) and the B&M flexplate for your neutral convertor.
thanks for the info moper! i guess wishful thinking on a cheaper bottom line but at least its not that much more.
Ben, I will take you up on that offer! it might be a few weeks since i am getting those j heads from Steve tomorrow and the show coming up but ill let you know when i get the funds back up.
Johnny, if you can use it - it's yours - as in FREE!
