tguss
I have a 360 block I used a digital caliper on piston bore , reading I got was 4.035 is this in specs of being 30 over ?? Thanks
Most pistons i have seen have the tolerances built into them. Forged needing more play than a cast piston. Have seen new cast 4.030 measure 4.028 and forged measure 4.025 +/- but still considered a 4.030 pistonall the wear is at the top.
wouldn't an .030 over be 4.030 bore and use a 4.028 piston?
