360 Cam
bjopau
Member
I putting a comp CL20-225-4 cam 284/296 .507"/.510" lift in a 360.
The heads are beeing rebuilt now with milodon 2.02 valves and new 1.60 valves ported and planed 0.40"
with that much lift do I have to do anything else or can it just be put in without any modifications?
New valve springs that can handle the cam,custom length pushrods. Check for interference betwwen the spring and rocker.Also may want to mill the intake surface some as the heads are sinking lower with that big cut.Could make sealing the intake difficult
