[SOLD] 360 Diamond Stroker Pistons and Eagle H Beam Rods - New
Rocket
CT
I have a new set of Diamond stroker pistons and Eagle H Beam rods for sale
The pistons are Diamond forged flat top pistons for a 360 with 4.0 inch stroke crankshaft. Diamond part number 51026. Specs are 4.030 bore 1.457 compression height -6.8 cc flat top forged pistons. These list for $750.
Eagle H Beam Connecting Rods Part # CRS6123C3D for Small block Mopar.
Specs are:
Rod Length Center to Center (in): 6.123 in.
Connecting Rod Material: Forged 4340 steel
Connecting Rod Finish: Shot-peened
Wrist Pin Style: Floating
Connecting Rod Bolt Brand: ARP
Connecting Rod Bolt Diameter: 3/8 in.
Connecting Rod Bolt Material: 8740 chromoly steel
Fastener Yield Strength (psi): 160,000 psi
Connecting Rod Bolt Head Style: 12-point
Approximate Connecting Rod Weight (g): 695
Rod Journal Diameter (in): 2.125 in.
Big End Bore Diameter (in): 2.2500 in.
Pin End Bore Diameter: 0.984 in.
Big End Width (in): 0.925 in.
Pin End Width (in): 1.060 in.
These list for $480
Price for both the pistons and rods is $1,000 shipped to the lower 48 states. I can ship to Canada also for an additional shipping cost.
Yes with a 4.0 stroke crank this nets 408 ci.
Compression assuming a 0.0 deck height, 0.040 thickness gasket and a gasket bore diameter of 4.10" the compression ratio is ~ 11.7 and with a compressed gasket of 0.060 and all else staying the same the compression ratio is ~ 11.1.
Your cam selection will be important is important in determining the effective or dynamic compression.
Specs are:
These list for $480
View attachment 1715021756 View attachment 1715021757 View attachment 1715021758 View attachment 1715021759 View attachment 1715021760 View attachment 1715021761 View attachment 1715021762 View attachment 1715021763 View attachment 1715021764 View attachment 1715021765
Specs are:
These list for $480
Interested in rods if you sell pistons
