[SOLD] 360 Dodge magnum engine block and crankshaft
Rocket
CT
360 Magnum engine block, crankshaft and damper. Pulled from a 2000 truck. It is the stock bore size of 4.00”. It came from the factory with a hydraulic roller camshaft. Block and crankshaft have had the machined surfaces greased and is why they look dirty or rusty. Price is $240 for the block, crankshaft and damper.
Block is in CT. PM me with any questions.
You need the 360 version of the brackets that attach on the sides of the block. Not sure if 273 and 273 are the same on both sides. Same biscuit mounts. Should not be a problem.
Hey I am thinking about buying the block as a spare no big deal if you sell it before I come hopefully on Wednesday I will let you know
Will that year block bolt up on a 67 Dart with a 273 k frame, or will it require major mod? Anyone know?
You will need the motor mount brackets to have it work. I know that the drivers side will have to be a 340/360 bracket, the passenger side can be used from a 318. You/re 273 passenger bracket may work.
Ill take it if its still available.Where in CT are you?. Do you have a PayPal address?
