360 drivers side manifold A-Body?
66 Barracuda
Did chrysler make the screwy drivers side manifold with 360 size ports at the head? Who's got-em that will squeeze in a 66 barracuda?
You could get a 360 in an a-body starting in '74 so they are out there. The 340 manifolds would also have a similar sized port.
Chuck
No big port version of the early A-Body manifold. You can always open the ports up with a die grinder. But the outlet is still small, and it gets pretty skinny around the column. No matter what, the early cast iron is gonna only flow enough to support 250-275 horsepower. Beyond that, they will start really holding you back. A dual pattern cam which favors the exhaust event will help some, but there is no silver bullet. Standard early A header angst applies.
