360 clicikng valve train
Getting way ahead here…..but let’s say it’s a magnum block……..
The easy button fix for that is rockers that are suitable for pushrod oiling and new pushrods.
If it’s not a magnum block……..it’s likely got bigger problems.
I expect all this talk about rocker shaft orientation is premature. The shafts WILL allow oil out, upside down AND backwards. It wont be in the correct spots, but it WILL still oil in my experience. I'd be looking hard to make sure it isnt a magnum block as mentioned, then I'd be thinking cam bearings
While I agree, it's still FAR from optimal if the shafts are on wrong.
What would you do have rocker shafts put on or go a different directions no disrespect to 70Dart I love that guy
I'm weighing all options from the professionals.
I would evaluate WHAT YOU HAVE first like we've ALL been telling you. :BangHead:
Everybody has an opinion I'm trying to weed out what is being said and i appreciate the help but
Don't kill this messenger
I'm trying
I'm trying
this is like pulling teeth. Post some pics of both shafts showing the oil holes locations as u removed them. Are the straight in line with the bolts? Pointing to the inside or outside of the of the head? It’s not that hard to post good pictures, if I can do it anyone can. U want help but u won’t help us help u.
I'm trying
Somebody correct me if I'm wrong please but don't magnum blocks have extra bolt bosses in the middle of the side of the block? I put yellow paint on the bosses for clairty.
Sorry old Kimmer I'm not nearly as smart as.you put your teeth back in
I'm trying
Nobody's killin ya man. You've been asked MULTIPLE times for pics, yet we have to go through another member to get them. Glad he's helping you, but you can do it to. We're trying to keep you from doing something you might not need to do. Killing the messenger? Hardly. We're trying to help and you're not making it very easy AT ALL.
Sounds like you need the Little River Band, hang on.
Can someone provide a picture so he knows where to look for the oil to come out.
