360 engine id
dartjack
Havelock, NC
Just picked up a 360. Has a Q-jet and twin snorkel air cleaner. Was told it was from an 85 Ram. Can anyone tell by the block #'s?
5K 360 8734 1
168082 135 9
Thanks.
figuring out mopar small block stamping numbers is very difficult. However the year of the block should be cast into the side of the block. this will give you an idea of what year the vehicle was that it was installed in. It suire sounds like it came out of an 1985 truck. I got a set of heads, intake and Q-jet carb out of a 1985 1 ton dodge van. It too had a dual snorkel air cleaner (which I snagged).
