360 from 76 Cordoba to 72 Demon
monoptn
Mopar Aficianado
Clarksville, TN
Using Schumacher conversion mounts, will the oil pan from the cordoba work in the demon? Many years a go i swapped a 360 into a 74 charger, and I had to put a different oil pan on it for it to fit.
Thanks!
Hmm - should be ok. I *think* the only difference in 360 oil pans is the 'centre' and 'rear' sumps. Rear sumps were found on truck engines. Was the 360 that went in the charger out of a truck ?
Good luck
There were only two types of pans from the factory. Car and truck. So if it has a car pan on it then yes it will work just fine.
I don't see why it wouldn't work, those cars are b-bodies, I used an c-body pan on my '72 Duster and fit fine.
Chuck
