Jon Melhuish
74Duster
Could someone provide a link to a site that will help me idenyify my old cast heads.
thanks
thanks
I don't know of a site but I do have a book with heads listed. Whats the casting #'s.
The numbers are AAWJ 360
1813
3671587-6
thanks Jon
Just for your reference Jon heads are generally refered to by the last 3 digits of the casting number so yours are commonly known as 587 heads. They were used on 73~74 360's and 73 340's. Some had air pump holes drilled and some don't. They have 1.88 intake valves and 1.60 exhaust valves and the chamber cc is spec'd at 72cc's but just so you know most are a little more than that as cast so the advertised compression ratio is usually a little lower than rated. There really isn't much difference between any 340 or 360 head made between 73 and 76 that I could ever tell. All had the same valve sizes and ports were very similar and flow close to the same. All sb Mopar heads were decent in comparison to the offerings from other manufacturers of the same time era IMO.
What i found 360-73-74 188-160 or 340-73 188-160.Go to google type in sb mopar head numbers.
