360 Ignition timing help
  • Thread starter Thread starter Deleted member 49442
  • Start date Start date
Hi Guys I was able to get the timing curve created.
Engine was warmed up, vac advance hose removed and plugged.
Idle is set at 820 rpm timing at 7
mechanical advance tops out around 2420 rpm timing at 34
So is the timing advanced enough?
or is it ok, and I can just adjust with the 94 octane fuel?
any thoughts on the timing?
Does it need more advance?
