ragtopfury
Located in Glen Burnie, Md, 21061. I have a stock crank, standard bore original pistons and stock rods from a 1974 360. Jake is stroking it out to 408 cubes, so the stock stuff is avail. Motor supposedly had 80k on it when pulled as a running motor 25 years ago. Also have the untouched original 2 barrel carb from it.
Crank - $50
Rods - $50 - plan on leaving the pistons attached, but will remove if you don't want them.
Carb - $25 - needs rebuild, I'm sure, but it all moves freely.
Prices are plus shipping at your expense. Local pick up is always an option.
Crank - $50
