360 LA using 904 Tranny
cuda guy
Hey everyone
Happy new year
I m just getting ready to install a 360 into my 72 Demon, the car had a 318 904
I want to use the 904
But what about the torgue converter and the flex plate what should I use, I heard if you buy a B&M flex plate you can use the 318 converter is this true
PLease any help would be fantastic
I also was wondering about the motor mounts
you are correct on the flexplate - either buy the B&M or have your current flexplate balanced. Motor mounts will need spacers (I've used the right thickness of nut) or buy 360 mounts.
Ya that's the right number...but $112.95? Is that with shipping? There are lots of pics and instructions on how to weld the correct weight onto the 318 converter.
I used the B&M 10239 on my 360/904 combo
Since you are there, maybe a little high stall converter?
Also you can pickup the motor mounts from Mancini - 318 to 360 upgrade - they are worth it
360 engine: 904 converter from the factory has two weights. Both the same, measure 1.62" x .75" x .380 ", and there is also another that has a single weight.
Converter rebuilders have a converter balancer for a reason. Have you checked out getting a rebuilt 360 converter? It may be cheaper than the B & M flex plate and will be balanced properly. Just a thought.
Do it RIGHT once.
Ya, I don't like a used 904 converter anyways. They love to crack cuz the wall gets thin down about half an inch below the slots. I guess that's why they went the ford route with two flats instead; on such a small converter.
Only left side engine mount will need a spacer and 1 longer bolt. Pic shown is a spool mount, but concept is the same. If using a non counterweight type torque converter, you will need to use a 360 flex plate for an externally balanced 360 if your engine is externally balanced. Most 360s are that way.
I did the same swap about 10 years ago and purchased a hi stall TC from Pat Blais (torqueflite Patty) on ebang. No need to change out the flex plate. I only see a 62-67 currently listed but you can give him a call. He is a stand up guy and the price was reasonable. No issues.
Torqueflite 904 1962-67 Rebuilt High-Stall 10-3/4" Converter - 1.55" CRANK PILOT | eBay
He needs the larger crank pilot size, 1.810", not the earlier small one. He hasn't said if he is wanting a high stall yet. From the factory, the 360 had two stalls, a low stall at around 1900-2000 stall and a higher stall one that could stall about 2200-2300. No mention as to what if any engine performance mods have been done.
Does anyone know what the part numbers for the motor mounts the Mancini web site does not show them
The B&M plate is the way im thinking of going since I have a new converter
